Has anyone tried using Voltawireless on the Teracube? I am getting 4g then 3 then H. i have to reset the sim constantly and was not sure if it is the volta service or the incompatibility with the phone.
any help would be greatly appreciated.
Hi @kurtahrens - welcome to Teracube forums. I checked out Volta wireless website. Not sure if they even support Non-Volta phones. It seems they use UK SIMs that roam in the US.
Thank you for the reply. I found that using two APN’s with the two options they gave which is Tn1 or RH that the sim locks in with Att and is working great. No more connection issues.
Thanks again.
