I obtained a warranty replacement for my 2e in August after losing it in June and it being found 2 months later next to the freeway in a smashed up condition. Now, for some reason, this phone has a few differences from my first 2e. For example, I wasn’t able to uninstall some the gApps that were uninstallable in my first one (I could easily disable them), and this one does have the camera that turns things blue when using the flash–my first one did have that problem a little, but this one does it quite severely. Also, the case fits just a tiny bit loose length-wise (maybe a resize because of complaints of the case taking the back off also?). Other than that, it’s still a good phone and works quite well. As I’m starting a business, I will be using my 2e as my business phone to keep expenses separate and easy to track. In my business, I don’t need to take indoor photos but I do need NFC and might need 2 SIMs, so it should work just fine.
I’m testing out a Motorola Moto G Power (2020 version) as my personal phone, We’ll see how well each lasts over time.
Immediately visible advantages of the Moto over the 2e include: better support for useful custom gestures (e.g. turning the flashlight and camera on and off are very easy to do on the Moto); better camera; faster cpu; higher resolution display; already can be upgraded to Android 11; works on every network that the 2e can access plus it works on the Verizon network; and, better display refresh rate.
Immediately visible advantages of the 2e over the Moto include: changeable battery; 2 SIM slots + SD slot; near field communication (e.g. tap to pay); case and basic screen protector come with the phone; better premium warranty included with the phone; the Android battery charge limiter is not removed from the battery options; has less uninstallable bloat (really, the Moto G lineup has very little bloat to begin with, but it does have an app or two that should be optional); rooting/installing other ROMs won’t void the warranty (Motorola will give instructions and allow you to modify the ROM or obtain root, but does it in a way that voids the manufacturer’s warranty on your device); and it is ethically sourced as much as possible.
The final verdict will be to see which one dies first.
