Teracube 2e T-Mobile Network Temporarily Unavailable
Hello. I’ve had my phone for 4 years now I think. A few days ago, it started dropping calls & the T-Mobile network would suddenly fade out. Then yesterday, unable to make calls at all. I’ve called & there’s nothing wrong with T-Mobile in my area. I’ve tried turning the phone off & on repeatedly, Taking the sim card out & putting it in the second sim card slot, taking out the battery for a bit then restarting. Nothing seems to budge the problem. Any ideas? I so hate to buy another phone. Thanks!
Sorry to hear that.
Can you share the first four of the serial, as well as what Android version you are currently using?
You can find this information in Settings
Hello, I was rather desperate to have a working phone so I ended up calling customer service. They think the phone has just gone bad & are sending a new one. Thank you anyways though!!
Ah, okay. Let us know how you get on!
Thank you!! It’s so amazing how dependent we get on our phones these days! I hope it arrives soon!
Since August 2026, I have suddenly had similar issues with T-Mobile and the Teracube 2e. The phone suddenly reports zero bars and no service–the mobile bars icon shows an exclamation mark.
I am using the latest /e/OS and had no issues previously. No changes. No updates (that I know of). The issue suddenly started around August 26, 2026. Note: this affects TWO seperate Teracube 2e units similarly so I am skeptical that this is a phone issue itself. Reports to T-Mobile suggest the Teracube 2e does not support Band 12 although the Teracube 2e specs seem to suggest the phone does support this band and no prior issues. This is frustrating as BOTH phones are now effectively dead when used at home (but seem to work in other areas). Anyone with any ideas?
If it helps, the first four of the serial numbers are 2021. The Android version is 16 (/e/OS 4.2-a16-20260815).
Do you know if they are changing the infrastructure in your region?
I have had ATT change the main band in my region, which resulted in me not having much service until I changed my SIM last week for a new one (I was still using my SIM from cingular wireless haha).
If your SIM is more than maybe 5 years old, perhaps try swapping that as well.
Even after upgrade to /e/OS 4.3 emerald, the issues continue. Zero bars. Also, /e/OS 4.3 remains broken so no WIFI calling.
Will a re-flash back to the stock/OEM Android (replacing /e/OS) fix this?
I have tried two physical sim cards–one for T-Mobile (about four years old) and one for Verizon (new, less than one month). BOTH report the same issues–zero bars and no WIFI calling.
Further, we have two Teracube 2e (2021) phones. BOTH behave exactly the same with cell and WIFI Calling issues–the sudden zero bars and then no WIFI calling.
I contacted both networks. T-Mobile suggests use WIFI calling. However, this is long failing/broken in /e/OS 4.3 (and in at least the prior version). There simply is no WIFI Calling despite strong WIFI signals. All the usual resets, APN resets, updates, reboots, etc. Nothing helps. (and there is some anecdotal eviddence that the WIFI Calling is broken in the upstream LineageOS).
I tested the same SIm cards on the same networks in the same locations with an old (c.2016) iPhone. Works well (still low reception but some) but including seemless WIFI Calling.
So, I think the issue is the OS. The chances two seperate phones would fail exactly the same at the same time are unlikely.
Does anyone frequentlty use WIFI Calling with the current stock Android image for Emerald to confirm whether WIFI Calling works reliably–I don’t want to reflash and then have another broken OS.
What is T-Mobile saying for your Emerald units using their BYOD checker currently?
