Best text monitoring app compatible with teracube thrive? I have family link and parental settings on my daughter’s phone. A few apps ive tried wanted me to change the battery optimization which it wont let me do. Ive priced a few but im unsure if they are compatible and no response back due to it being the weekend.
Hi @Tesla - could you provide names or links to the apps you are mentioning? We can install and test them on Thrive and give you feedback.
Sms tracker and various others off google play store, sms forwarding apps. Mspy, guardian pro, bark, spyic, (these are not on google play).
Hi there - all these apps except Bark seem a bit shady. Could you tell me what problem you run into when you try to disable battery optimization?
