I need a new screen protector for my Teracube 2e. Why is it not for sale anywhere?
What region Store are you using?
We have it available in the US Region, for instance:
Not available in US store - it was $20 for two really?
Amazon.com: Supershieldz (2 Pack) Designed for Huawei Y6s (2019), Huawei Y6 (2019) and Huawei Y6 Pro (2019) Tempered Glass Screen Protector, Anti Scratch, Bubble Free : Cell Phones & Accessories
This is currently available for the same phone mentioned as a size-dupe above. Two screen protectors for 7 bucks.
Quick sidenote on the screen protector I linked above 25 days before - finally installed this after my detached (for several months) screen failed to survive detached drop 15 or whatever. Yay for case holding it semi-in-place. Should probably have glued it. Maybe next time. But I’d purchased replacement screen when the initial detachment happened, so it was all fine. Anyways, back to the protector review.
The new protector is all clear glass with no blacked-out bottom like the one available in March 2021. It does have the top notch cut-out, so the front camera stays uncovered. The size of the protector covers most of the screen, but leaves about a 1 mm lip around the screen, which means that it actually fits well into the case and doesn’t try to lift the display constantly. As such, you might consider installing it while in the case, so you’re able to make sure it’s properly centered.
All in all, I greatly prefer the new all-clear protector both for looks and functionality.
