Time on bar not correct
The time on the bar that shows the 3g and battery usage is not correct. The other large time display is correct. Any thoughts?
Just to confirm - did you install the software update (SW6)? This problem was one of the things fixed in the update. If you are not sure, could you tell us your Build number from Settings > System > About > Build.
And here is the article on how to install the software update.
I will check. It’s my wife’s phone. Thanks
