Hey everyone,
I have been using my Teracube 2e for a few months now and overall, I am really happy with it. However, I have noticed the battery life isn’t as great as it used to be.
I am usually just browsing, texting…, and using a few apps like Spotify and WhatsApp, but I am finding that I need to charge it more often than before.
Has anyone else experienced this: ?? Do you have any tips for improving battery life: ?? I have already tried the usual stuff like lowering the screen brightness, turning off Bluetooth and GPS when not needed, and even using battery saver mode but I am still looking for more ideas.
Also, does anyone know if there’s a way to check which apps are draining the battery the most: ?? I also read this thread on the forum https://community.myteracube.com/t/best-battery-saving-methods-azure-admin/ but still need more help.
Any advice or suggestions would be really appreciated…!
Thanks in advance for your help…!
David Miller
