The TracFone BYOP SIM kit comes with SIMs for Verizon, AT&T, and T-Mobile if I’m not mistaken. I’d like to use the T-Mobile one if possible.
Will that work?
Will that work?
It should since it’s able to be used on T-Mobile bands! I use Metro by T-mobile, so I can’t say I’ve tried Tracfone, but since they’re on the same network (T-Mobile) it shouldn’t be an issue.
Did you have to modify the APN settings?
With Metro? I didn’t have to. (I should also mention I’m on the Teracube One as well, so it may be different with the 2e.)
Hi @GregL - you should be able to use TMobile settings from here. On a somewhat related note - here is how I had gotten Tracfone on AT&T to work.
Thank you for that info. Much appreciated.
