This is probably a really duh question but I can’t figure out what is the setting to get the selfie/user facing camera to flip the image so its not a mirror image. As it is, the writing in the photos is backward. It should be a simple setting - in the past my phones had a setting marked flip or mirror off… and I just can’t see it. Skimmed the manual and didn’t see anything online either. Advice? Tks in advance.
Hi @researcher - welcome to Teracube forums. The built-in app does not have this feature as you found out. Here is a howto on this topic.
Thanks much for the heads up and suggestion.
I will try Snapseed, though I wonder if its a simple enough feature to integrate in a future OS or native app update.
