Hello,
Just started using the Terracube 2e and can’t get the video recorder to work. I get an “unknown error, video halted” message when i try to record. Is there some way i can fix this? Thanks.
Hi @Fenix - welcome to Teracube forums. Few questions:
Could you confirm if your serial number starts with 2021? Serial number can be found on the box, under the battery or you can dial *#06#.
Are you able to take pictures with the camera?
Are you trying to save on the SD card?
Go to Settings > Apps & notifications > Search for “Camera” > Storage > Clear Storage.
4.1 Try taking video again.
