Hello. The weather screen app is not working correctly so want to remove as it cannot properly input my location. How can I remove it from home screen?//thanks
Hi @Harold - welcome to Teracube forums. The weather screen app is provided by Google. If you are not able to use it, then you have few options:
- See if you can remove the widget that shows weather. Tap and hold that area to see if you can drag it to “Remove”.
- You can install alternate launchers from Google play store like Nova launcher, Microsoft launcher or open source Lawnchair v2.
