Why no CDMA support?
What is the reason CDMA carriers are not supported? Any chance of this changing?
You should investigate becoming a device supported by CREDO Mobile. They are a very progressive mobile company that donates a portion of their revenue to progressive social causes. Seems right up Teracube’s alley!
Extremely expensive to get certified, and on its way out. Search the forum for further discussion of this.
According to PCMag’s article, “Verizon will turn off its CDMA network and T-Mobile will turn off its 2G GSM network by the end of 2020. In 2021, AT&T and T-Mobile will keep their 3G networks in very low-bandwidth modes mostly designed to support devices like electric meters and vending machines. Now that T-Mobile owns Sprint, it’s likely to do the same with Sprint’s old CDMA network. That means 2G/3G reception and call quality will likely be poor, if you get a signal at all. It’s a 4G LTE world now, and if you aren’t in it yet, it’s time to switch over.”
Agree, I wish they make as Modular and reparable is a plus. Or more varieties of Teracube devices as Laptops, Tablet like Framework, SHIFT13mi, and PineTab 2.
