I just received my 2e. In setting it up, I noticed that after about 30 minutes the phone starts dropping wifi and changing networks. The phone serial number is 202011T2E000440. All other wifi phones OK. Please advise.
Few questions:
- Does your place have multiple wifi networks with different SSIDs? Or does it have a mesh wifi network?
- Can you tell us the brand(s) of your wifi routers?
I have two networks and an extender on one. So three access points.
- Could you share the brands of your Wifi APs?
- Is 2e shuffling between the APs?
2.1 Is it better if you put only 1 SSID on 2e? - Can you check if you have fast roaming enabled? If yes, could you try disabling it?
Sharad - I believe the problem may be AP related. I will contact ATT. If I have a repeat incident I will be in touch. Thanks!
