Hi, I just recently began to have an issue with WiFi disconnecting on my T1, sometimes the WiFi will last an hour, sometimes 5 minutes, but it always stops functioning at some point until WiFi is turned off and then turned back on (it used to require a phone reboot before updating software a few hours ago). I have had the same routers in use since before my T1 and until this week there has never been an issue.
today I upgraded to the A10.0.1 to see if anything would change and the only difference is not having to fully reboot the phone to get WiFi to work again.
I have 3 different routers in my house and separate 2ghz/5ghz ssids for each. I can join any of the networks and switch between them right after starting wifi, but after a failure reconnecting or switches networks always fails.
I created this new thread as the other WiFi keeps disconnecting was focused on mesh networks, while my routers are all basic units (although it won’t connect to Comcast xfinity wifi (public wifi hotspots from my ISP) either after it fails)
tried a few different settings on the base station, but hasn’t seemed to help anything. I don’t notice the issue on other routers, but I’m rarely on someone else’s wifi so tough to say definitively.
