We set Teracube’s default window animation speed to be pretty smooth (to be comfortable for everyone). This is the speed at which app windows come up or switch to other apps. I personally like it to be slightly faster. Here is how you can try faster switching :
- Enable Developer mode
- Search for “window” in Settings. Select the option “Window animation scale”
- Set the 3 properties : “Window animation scale”, “Transition animation scale” and “Animator duration scale” to be 0.5x (default is 1x). You can try “off” as well - that is too fast/abrupt for me.
