Has anyone been able to set up wireless Android auto using the Terracube 2e. My Samsung works fine but not this phone?
I’ve had no success with using Android auto wireless. Are you still having troubles? Thanks
It depends on your vehicle and if it is wireless auto enabled. My 2017 Chevy Cruze is not wireless projection compatible and there is no factory update for the car’s head unit. Running on a cable, it is.
Hi mlrsmp
Thanks for your reply. I’m the same as Gerard. My car is wireless enabled and I can connect with my work Samsung phone ok just not my teracube 2e.
