I’m definitely doing something wrong. Have a 2e 2022 batch, enable bootloader successfully, and flash lineage onto the device. Phone boots to this error: “Can’t load Android system. Your data may be corrupt. If you continue to get this message, you may need to perform a factory data reset and erase all user data stored on this device.” - pressing the only option (Try Again) reboots the phone and gives the same error. I’ve successfully flashed back to the factory defaults and tried again, but with the same results. Any advice?
Computer is Windows 10, if that helps. No errors during the flashing or anything
EDIT: After further trial and error, I got it working. Not restarting the phone after restoring to factory settings seems to have done it, no idea why. Gonna leave this post here in case anyone else encounters this error.
