Looks like an environment issue, but I’ll have a look.
It seems really to be a problem of dust near the sensor. keeping it and the gap to the cover clean solved this issue (for now, lets see
There seems to be something wrong with your link… i can’t use it.
I cannot use the link either, but here is the github release page:
https://github.com/teracube-mt6765-devs/releases/releases/tag/1.3
Error on my side. My apologies.
Link’s been fixed. Please let me know if any more issues persist.
Happy flashing!
I never did an update manually (LineageOS did it for me and used TWRP), can you explain how to do an update (without loosing anything of course
And my question if the TWRP mentioned with the 1st batch works with the 2nd batch too wasnt answered yet or i missed it. Is there a different one or is it just the same?
Hey, so in a nutshell, the TWRP version for 2e (first batch) will not work with 2e (second batch) over partition differences, and a few more issues, for example, the kernel.
I personally do not recommend TWRP for flashing/updating, because at least for me it broke OTA updates and a lot more things. (Was a common issue across devices)
For flashing OTA Images, I’d like you to follow the below instructions:
- Connect your Teracube to your PC
- Reboot to recovery
$ adb reboot recovery
- Tap Apply Update, and then select Apply from ADB
- Run adb sideload on the Lineage OTA package to flash the build.
adb sideload lineage-18.1-xxxxxx.zip
- Wait for it to flash, then go back to the main menu and reboot.
Simpler method to reboot to sideload where it’ll auto reboot is adb reboot sideload-auto-reboot but that’s untested. You can try that out as well, and let me know what works.
The next coming builds for April will have OTA and everything else functioning, so it will be lesser of a hassle for you
Spoiler: Lineage + Google Apps builds coming very soon!
Do let me know if you require such builds.
will do.
no thanks, i use lineageos exactly because its not contained
i see this image of a layed down android with opened hatch and the text “No command”. it can do sideload adb tells so i give it a try.
it ends in serving: 'lineage-18.1-20220331-UNOFFICIAL-emerald.zip' (~94%) adb: failed to read command: Success and a black screen and boots after a while. no clue if i have the new system now… where do i see that?
fun fact: i never had to enter a sim pin when rebooting a 2e.
Check About Phone - you will be able to see March patches.
As for Google Apps, I know a few users might want Google Apps as well so I’d want to give them the choice
i found the build date instead which is Feb. so no: that flow didnt work
i did the other flow (using the menue in the recovery) and ended in the error adb: failed to read command: Success as well. looking at the build date still shows Feb.
sure, i know, no problem with that but i can’t help
Today i had the time to redo the flow with ADB_TRACE=all. this shows:
serving: '/home/mdt/Downloads/android/blobs/2e/lineage-18.1-20220331-UNOFFICIAL-emerald.zip' (~94%) adb D 04-04 07:31:01 19726 19726 adb_io.cpp:81] readx: fd=7 wanted=8
adb D 04-04 07:31:01 19726 19726 adb_io.cpp:97] readx: fd=7 wanted=8 got=8 3030303130313036 00010106
adb D 04-04 07:31:01 19726 19726 adb_io.cpp:81] readx: fd=6 wanted=8611
adb D 04-04 07:31:01 19726 19726 adb_io.cpp:97] readx: fd=6 wanted=8611 got=8611 0cf0244fb5b626e0ffac7ee571adb8d5 ..$O..&...~.q... [truncated]
adb D 04-04 07:31:01 19726 19726 adb_io.cpp:107] writex: fd=7 len=8611 0cf0244fb5b626e0ffac7ee571adb8d5 ..$O..&...~.q... [truncated]
adb D 04-04 07:31:17 19726 19726 adb_io.cpp:91] readx: fd=7 disconnected
it seems the mobile terminates the connection at 94% of the image. it seems to be a problem in the recovery code.
btw:i found that the menue of the recovery has some invisible menue entries. if you navigate via volume up / down one can select hidden entries (the selection just disapears). other way you cannot end the sideload mode anyway (took me a while to find that out).
if you prefer issues at github let me know, as well which repo to use for the recovery.
For hidden options, I have fixed the recovery in the newer release.
Try flashing the build with userdata unchecked via SPFT, that is the best way to flash builds as of now. Once stable builds roll out with OTA and stuff most of the issues will be ruled out.
no clue what you are talking about
what is SPFT?
Ah, found it. There is no source for that tool or am i wrong?
Correct - we do not have sources for the SP Flash tool.
does the tool use fastboot or sideload to communicate with the 2e or does it have a special method?
can i use fastboot to update or do i loose something that way?
this is my flow:
#!/bin/sh -e
fastboot --set-active=a
fastboot flash boot boot.img
fastboot flash dtbo dtbo.img
fastboot flash vbmeta vbmeta.img
fastboot flash vbmeta_system vbmeta_system.img
fastboot flash vbmeta_vendor vbmeta_vendor.img
fastboot flash super super.img
fastboot reboot
SP Flash Tool uses BootROM/Preloader mode to communicate/flash devices. It is a proprietary MediaTek protocol.
You can use fastboot, absolutely.
The script you’ve given should work fine, without issue. If you flash all the partitions one by one via fastboot that works too.
It’s just that SP Flash Tool is way faster than fastboot xD
Ok, just flashed the new image via fastboot, it boot fine & works. Lets see if the reboots and long gc runs are gone.
And btw: Thank you all for your work on putting LineageOS to the 2e. Whatever others tell: I am quite satisfied
Glad you got it to work <3
