Port, cable, and device all are functioning properly.
I already wiped all data.
I can load PE Recovery.
But I want to install Android 12 on it and see if that helps with the GPS and battery draining issues.
Have you checked with the pixelexperience devs what those errors mean?
Status 1 typically means failure (of some sort). Is the sideload image corrupt, maybe?
I have and I tried with different images.
But regardless, I should be able to flash.
This is starting to sound more and more like a hardware fault.
I must again recommend that you consider sending it for warranty replacement.
Android 12 alpha for Teracube 1, are spflash tool images. Not recovery flashable images, flash them using sp flash.
Thanks
The problem is that the phone isnât being detected in SPFlash
A new alpha firmware is available, [Alpha] Android 13.0.4 for Teracube One Ruby (SN:2019) - #2 do check it out.
Upgrade to Android 16 now!
