Android 14 Is causing me a ton of problems
Here to share my experience, hoping someone will be able to help or give me suggestions.
At first I didn’t have much problems with my phone, but since i updated to android 13 It started to slow down and It took vert long to reboot so i decided to non update It anymore to avoid making It unusable, but some weeks ago It started to have issues with my digital wallets and i wasn’t able to pay anymore.
I tried to factory reset but it didn’t solve anything, and contacting customer support they told me i needed to upgrade to the last available version, so i had to update it hoping It would solve something, but It only made things worse.
Now the phone Is much slower and some times It freezes forcing me to force reboot by holding the Power button(the reboot process seems to me a litte faster but still very slow), finally, also the Google wallet issues got worse since I found out in the play store that this version doesn’t have the play protect certification, meaning that this update didn’t fit Google security standards and it doesn’t let Google wallet run on uncertified devices.
Am I the only one who’s having this kind of issues?
Was anyone able to solve them somehow?
Do anyone know if it’s scheduled some update that could solve the wallet issue?
Would downgrade my phone help with the slowness? And eventually what should I do to downgrade my phone to android 12/13?
I already tried to contact customer service but It just proposed me a replacement, and this could help if i was the only one having those problems, but if this issue Is something general I see no point in transfering all my datas to a different phone with the same problems
The Wallet issue on Android 14 is known and the team is working on an update to fix that regression.
The slowness and freezing is not commonly seen, no.
Are you using a microSD Card as shared storage perhaps?
Thanks for the answer, do you have any idea how long could It take to have an update?
No, i’m not using any external storage
I do not have a timetable yet, unfortunately, but the team will update here as soon as the new image is ready to use/test.
