NOTE 1 : These builds ONLY WORK for the Teracube 2e 2nd batch (SN: 2021) Emerald, and not 1st batch (SN:2020). Please read the differences here carefully and install accordingly.
If you are looking for SN:2020 T2e (Zirconia), you can find it here.
NOTE 2: All firmwares released for Teracube 2e (2020) & Teracube 2e (2021) don’t pass Play Integrity this includes Android 10/11/12/13/14/15. We’ve explored all options, but implementing Remote Key Provisioning (RKP) a strict requirement for Strong Integrity is simply not feasible for us right now.
NOTE 3: It is expected for the device to stay longer on Teracube logo for the first time after installing the upgrade & The device may respond slow for some time after upgrade, apps are optimising in background. We recommend waiting 15min on idle post upgrade before using it for an optimal experience.
We are thrilled to share our first stable (16.3.1+e42f634) Android 16 for Teracube 2e 2021 as it shipped out with Android 11 all the way to Android 16 QPR2
What’s New?
First boot after OTA may take a few extra minutes to settle.
June 2026 security patches
Improved app launch speed
Better multitasking & less app killing
Performance & battery improvements
Faster animations
Fixed apps not updating
Fixed Play System Updates crash
Fixed wallpaper not applying
OTA update progress now shown in boot animation
Launcher app suggestions disabled by default (can be re-enabled in Launcher Settings)
Disabled haptics in launcher
General stability & cleanup improvements
Steps to Upgrade:
- Goto Settings > System > Updater (or Teracube Updater)
- Click top-right 3 dots > Local update or Click on the top-right File icon
Note 3 : Before you update, make sure you have at least 6GB of free storage and your battery is at least 50% charged. This will help ensure a smooth update process. - Select the file and continue the update process.
Note: If the Updater closes or crashes, then try again. - Upgrade process will take a while.
- Reboot the phone after the updater says “Update installed”.
- First boot after upgrade can take several minutes.
Do note, after the update, you’ll need to re-enroll your fingerprint and some users have reported that they lose their launcher - icon and widget arrangement. We’d suggest you take a screenshot of your homescreen before performing the update!
If you experience any errors/issues, you can install the original factory software using the automated installer or SP Flash.
Faster animations
