[Beta] Android 11-April 2022 (A11-SW7) update for T2e 2nd batch (SN:2021)
Note : This update is for the 2nd batch of T2e (SN:2021; Emerald)
** Warning **
  1. Please backup your data before proceeding.
  2. Not for the faint hearted. This is Beta software. If something goes wrong, you might lose your data and might have to re-flash factory Android 11 using SP Flash software.
  3. Few apps might not be available in the App store like Netflix, Disney+ (this is due to the build not yet certified by Google). Install them before hand to continue using them.
This is mostly a security patch update on the factory OS version (Oct 2021) with few minor changes. Certification is in progress.
What is new
  1. April 2022 security update
  2. Google Play system update can be updated to March 2022 (latest).
  3. Google search bar has moved to the bottom (Google has a hand in this).
Known issues - What does not work yet
  1. Certification in progress. You won’t find Netflix and Disney+ in the Play store.
Steps
  2. Goto Settings > System > Teracube Updater
  3. Click top-right 3 dots > Local update
  6. It will take a while. The phone will power off and restart by itself. Don’t press power button.
  7. Restart the phone manually after the updater says “Update installed”.
If you experience any errors/issues, you can flash A11-SW5 (original Android 11 firmware for SN:2021) using these instructions.
