Update: Please refer to latest update here - SW15.
Summary
** Warning **
- Not for the faint hearted. This is Beta software. If something goes wrong, you might lose your data and might have to re-flash SW6 using SP Flash software.
- Few apps might not be available in the App store like Netflix, Disney+ (this is due to the build not yet certified by Google).
Changelog
- April 2021 Security updates
- AT&T certified
- Bluetooth streaming/range issue improved.
- Blue photos under flash fixed.
Note1 : This upgrade is only for US, Canada and other non-EU countries.
Note2: It can be upgraded both over the original factory firmware or SW13.
Steps
- Download the upgrade zip file directly on the phone (or transfer the zip to the phone). Note - its a big file.
- Select the file and continue the update process.
- It will take a while. The phone will power off and restart by itself. Don’t press power button.
If you experience any errors/issues, you can flash SW6 (original firmware) using these instructions .
     Plus, voltage was 4.3v, which is definitely fully charged), now SW14 shows 100% as it should. So that’s a big one fixed.
