This is no longer supported. Please refer to SW16 or a newer update.
Details
** Warning **
- Not for the faint hearted. This is Beta software. If something goes wrong, you might lose your data and might have to re-flash SW6 using SP Flash software.
- Few apps might not be available in the App store like Netflix, Disney+ (this is due to the build not yet certified by Google).
We have another small update over the 2 (SW13 and SW14) that were released in the last 2 weeks. This one will be the last before we get it GMS certified (unless there are any bugs).
Changelog
- May 2021 Security updates
- AT&T certified
- Bluetooth streaming/range issue improved.
- Blue photos under flash fixed.
- Notification shade dropdown issue fixed.
Note1 : This upgrade is only for US, Canada and other non-EU countries.
Note2 : It can be upgraded both over the original factory firmware or SW13/SW14.
Steps
- Download the upgrade zip file directly on the phone (or transfer the zip to the phone). Note - its a big file.
- It will take a while. The phone will power off and restart by itself. Don’t press power button.
If you experience any errors/issues, you can flash SW6 (original firmware) using these instructions .
Don’t let my “next on my list” wishlist dampen the praise. Y’all deserve a party - but that party will come when it’s certified and released
