Can not make outgoing call
cannot seem to call out…says calling but there is no ringing heard and after bit, just auto hangs up…call does not go thru to recipient.
seems like most calls incoming are working, just when I try to call, it does not work
any suggestions?
rather frustrated
Could you tell us your country/city and wireless carrier. Also, could you try these steps:
  1. See if a reboot fixes the issue.
  2. Goto Settings > Apps & notifications > Phone > Storage. Clear cache and storage. Reboot and try again.
toledo,oh
AT&T
Thank you. Let us know once you are able to try out the steps mentioned earlier.
Your specific steps made it possible for me to make an outgoing call to my daughter successfully!
Now will see how long the solution works!
Thanks,
Cheryl
Glad to hear that.
2 posts were split to a new topic: Dual SIM - outgoing call not working
