Note 1 : There is the 11.0.4 update available now.
Note 2 : This update is for the 1st batch of T2e (SN:2020)
** Warning **
- Check Known issues below before proceeding.
Here is our 2nd stable and (Google) certified Android 11 for Teracube 2e (1st batch; SN 2020). Little performance boost, battery improvement, and few bug fixes. Full list below.
Fixes from 1st build 11.0.0
- Fixed FM
- Fixed Hotspot
- Performance Improvements (Set up pinner, set up new power interface, CPU & GPU boosting, MTK power hint triggers in AMS)
- Double-tap to sleep on lockscreen
- Fix Launcher crash on double tap to sleep
- Improve camera loadup performance
- Fix GSI bootup (advanced users)
What works
- Google Certified - so Google Pay, Netflix, Disney+ all work.
- Will work for all regions (US, Canada, UK, EU, Rest of the world)
- Bluetooth music and calling, NFC, WiFi, Cellular, VoLTE - all work
- Notification LED behavior fixed.
- Bluetooth range and music skipping issues should be fixed.
Known issues - What does not work yet
- Not a bug but more of an Android 11 feature. SIM cards can’t be disabled individually for Dual SIM setups.
- Performance is still being tuned. You may experience some slowdowns .
Steps
- It will take a while. The phone will power off and restart by itself. Don’t press power button.
If you experience any errors/issues, you can flash SW6 (original Android 10 firmware) using these instructions.
