[Certified] Android 13.1.1 for Teracube 2e Zirconia (SN:2020)
I did the clean flash factory firmware reset. This got me back to Android 10. I was able to install 13.2.0, and it appeared to work initially. I did the initial setup and powered it off to recharge. But when I powered back on, it got stuck in on the initial Android screen for over 20 minutes. I tried to hold down the power button to force a power off, and then it went into a boot loop.
I did the clean flash factory firmware reset again, and installed 13.1.1. This appears to reboot normally, without getting stuck on the Android screen, or in a boot loop.
It takes 3-4 minutes on android screen. Google is behind that for loading modules. It might also be updating Play system updates.
Did you get through it?
Yes, I am running on 13.1.1 now. It seems stable. NFC doesn’t seem to work though, and I can’t save photos onto the sdcard using the default camera app.
Android 13 made a number of changes to how things can read/write to external storage.
You might want to try OpenCamera, and enable Camera API 2 and Storage Access Framework (required for apps to write to external storage).
This could be an oversight, or general dumb question…
… but the top post doesn’t appear to link to the zip file?
I swear, I’ve read that thing 6 times, looking for the friendly link, so I can attempt to DL the latest version… But it’s not there. (The Emerald version has a link in ITS post, all blue and clickable… But not here.)
I’m currently stuck at 13.0.3 - the OTA update to 13.0.4 has been sitting in my System options for months, but it doesn’t take.
I wiped and factory reset once, several months ago - and it stalled at the same update again.
I just wanted to see if updating would fix some of the random freezes and resets I’ve had for ages.
Seeing a RECENT update, rather than the OTA from last June, got my hopes up… :wink:
Maggie in Canada, who would rather not have to save for a Fairphone.
Here’s the direct link:
https://downloads2.myteracube.com/T2e/2020-zirconia/internal/13.2.1%2B6104348.zirconia.user/full_zirconia-images-13.2.1%2B6104348.zirconia.user_signed.zip
It is the text that says ā€œAll other Zirconia usersā€
Thanks!
Now I feel like a doofus… apparently I HAD clicked on that, probably during one of my passes through the notes - but the download didn’t show up in a notification - so it’s been sitting in my folder waiting to do the local update since before I posted.
SMH
Keeping fingers crossed that this improves how my phone behaves.
Maggie
On my phone the updater won’t updated past the Dec 5, 2024 update. It did once update to December 27, 2024 (I forget the exact date), but then reverted back to Dec 5.
I’ve download this file three times to do a local update, only to get a ā€œFailed to import local updateā€ error. I’ve factory reset the phone before trying and it still fails. Can you confirm that the file linked is valid?
It is what I use to flash my devices, so it should be valid, yes.
This thread is for Zirconia (2020x) serial devices. Can you confirm you have Zirconia?
New shiny Android 14 is available, [Public Beta] Android 14.0.1 for Teracube 2e 1st Batch (SN: 2020) - #2
I have a Zirconia.
It’s moot now. I downloaded the Zirconia 14.0.1 beta which is installing now. I’ll update that thread once it’s done.
Also cannot perform local upgrade on Zirconia from 13.1.1, the same error appeared. Tried to download archive several times, no progress. Don’t want to use beta on my device - any other suggestions? Or will the image be published OTA as 13.1.1 was?
If the update function fails after manually downloading the update, it will fail when trying to update if it’s available as an OTA as well, as the function that’s failing is the update function rather than the download. Unless the issue is that your browser’s downloads are consistently failing, in which case that is likely to continue when the OTA downloader uses the same web backend.
I assume so, hence it’s not bug report, but rather call for… I don’t know, rebuild? It should be stable release, so I tried upgrade (from 13.1.1 to 13.2.1) which should be normally possible. Any other way then, or possible re-release since re-appearing errors? Android 14 is still in beta, so let the team take their time, I guess.
Can the thread be updated to provide a download for the latest (last?) version, which I believe is 13.2.1?
