Does teracube 2e work in China?
I am considering buying a teracube 2e. However, I am going to visit China soon. Is there anyway to check if the phone works in China?
Hi @newptcai - thanks for posting in Teracube forums. Based on the list of China cellular bands mentioned online, it seems that T2e may get some coverage but may experience issues in some areas as well. It’s best not to be used as the main device there. Common bands - 3G (1 band), 4G LTE (1 band)
References:
  1. https://www.frequencycheck.com/countries/china
  2. Teracube 2e Specs
Thank you. Do you mean that among all bands used for LET in China, there is only one supported by teracube?
That’s correct.
