/e/ OS installation for Teracube 2e (both batches)
/e/ team has released instructions for installing /e/ OS (aka eOS, Murena OS)
  • Please read all instructions and Caution statements carefully
  • Please identify your T2e batch carefully before proceeding. Your batch may have changed if you got a replacement phone.
Suggested Method
Use the Easy /e/ installer. Works for both batches.
Alternate steps for installing /e/ OS
** Caution **: Never erase or wipe memory using SP Flash. Only use “Download” mode. And please get the latest version of SPFlash from our forums.
These direct steps are more involved than the above mentioned easy installer.
T2e 2nd batch (SN:2021 ; Emerald)
T2e 1st batch (SN:2020 ; Zirconia)
ps: If you you would rather buy Teracube 2e with /e/ OS pre-installed, then you can buy directly from efoundation here.
Looking at trying this for the fun of it but the caution messages are slightly worrying. Should I still do this if I’ve updated my 2020 2e to Android 11?
Update to Android 11 should not affect the installation steps (the partition table is still the same).
A post was split to a new topic: /e/OS EasyInstaller Issue
