Echo on voice calls?
Is anyone else having others complain that they hear an echo of their own voice when on a call with you on your Teracube? I’ve had 2 different people complain of this. I tried taking off the case, and lowering the in-call volume, but neither seems to help. Talking on the speaker is the only apparent solution.
We have had few people experience that - during regular earpiece calls. The other side hears echo of their own voice. The temporary solution is to keep the Teracube volume at 50% - this has worked in all cases. Let us know if that works for you. We are working on full fix for this - might take some time though.
As you mentioned this is not an issue with speakerphone calls.
8 posts were split to a new topic: Echo on speakerphone calls
