FIngerprint Sensor Failed
My fingerprint sensor seems to have failed with no discernable reason aside from possibly too hot ambient temperature.
I am running the stock v10.1.0 ROM, I have rebooted, I have performed the cache reset multiple times.
I can not get the TeraCube to do an in-place/reflash of the v10.1.0 ROM, so I’m not sure what to try next.
Resetting the phone is not an option as my father just died and I have lost RCS messages in Google’s awful backup during previous resets, and I will not accept losing any of his messages.
Sorry to hear about your father @Saijin_Naib. I’ll suggest you use an SMS backup app, like this one.
I can think of reset as being the only way to figure out if this is a hardware fault or a software glitch.
Thanks, Sharad.
I have a license of SMS Backup Pro, but that (nor anything else) can backup/restore RCS messages, and my family and I have been on RCS exclusively for over a year now, hence my dread of losing his messages.
Does it make sense that an in-place upgrade of v10.1.0 fails early on, or should that go through no matter if I’m already on v10.1.0?
We haven’t tried that - can ask the Dev team to check that. What are you trying to achieve with that?
Hoping that I can do it twice in a row to ensure that both A and B partition images are sane and have fresh copies of all files to rule out OS/file-level corruption and see if the functionality of the fingerprint sensor returns.
Barring that… Yeah, looks like reset/new device are my only options.
Dev team said the in-place update should work but will not change anything.
Thanks for confirming.
Something is very broken then to have the in-place fail almost immediately each time.
I wonder if the Android Developer/Debug Full-Device backup over USB would preserve RCS messages? I’ll need to test that.
