[ How-To ] Factory Reset (Erase all user data)
Before you proceed
  1. Try this soft app settings reset
  2. Try resetting your network settings. Goto Settings > System > Advanced > Reset > Reset wifi, mobile & bluetooth.
  3. Ask/search on forums to a specific solution to your issue
Steps to perform a factory reset
  1. Please make sure
    – You are backed up (Settings > System > Backup).
    – Your pictures are backed to Google photos or some other backup system.
    – And you remember your google password :slight_smile:.
    – Read the post below.
  2. Then do Factory reset (Settings > System > Reset options > factory reset)
If touchscreen is not working or broken, then follow [ Troubleshooting ] Factory-Reset with No Touchscreen.
Fingerprint setting and call problem
NFC not working?
Clock in top left incorrect
Youtube and whatsapp issues
No GPS signal
Battery issues
Total chaos
Bluetooth with Garmin vivosmart band
Play Store, Browsers crashing?
NFC not working?
Not able to answer a phone call
Android auto working?
Att can't turn on data
Delay when sending text messages
[ Basic Troubleshooting ] Battery life or other unexpected issues
Teracube One screen not waking up during call (After SW7)
Sometimes my phone freezes
Screen unlock by fingerprint unavailable
[ Information ] Teracube 2e User Guide
Issues with mobile network after upgrading to Android 10
Wifi disconnecting on 2e
Teracube 2E will not accept SD card
[ Troubleshooting ] Cellular data not working
Gboard keyboard swipe multiple false touchpoints
Wifi keeps disconnecting
Suddenly lost calling capabilities
Teracube 2e with Tmobile (ex-Sprint)
Battery life has tanked since updating to android 11
Camera issue
T1 Lost Data Connection ("Roaming") w/Mint
Teracube wants me to send them my phone but I cannot factory reset it
Wonky GPS on 2e with eOS - Fixed!
Incoming phone call audio "mostly" gone!
Settings app keeps freezing
Nfc not working
FIngerprint Sensor Failed
Having some frustrating issues- How can I fix them?
Wifi range low on a replacement unit?
Simcard slot 1 not reading Simcard
Casting to tv not working after 11 upgrade
[Certified] Android 11.0.4 for Teracube 2e 1st batch (SN: 2020)
Notification Bar Query
SD storage does not work
Teracube One Phone screen not waking
Trouble with Backup to Google Drive
Phone automatically shuts off
Issues with reception
Will I lose my data?
Google backup (check to make sure it is on) will bring all texts, contacts and phone settings back. Your photos can or are already backed up to Google photos or some other service (good idea in general). Most other apps (like banks, social media, games, etc) usually have their own cloud login and backup.
Note : Make sure you remember your google password.
Google backup will also install all your apps but will not configure them for you. So you might have to login again into your banking apps, social media apps, etc.
Thanks Sharad, since my screen doesn’t work i can’t back anything up anymore, but I had backed up my photos to google drive, my text msgs were on the google msg app which is web based so will those auto back up? Also my contacts I think should be backed up either by sim card or my Google acct right?
Text msgs are now backed up by Google (regardless of whether you use the web version or not). And yes - the contacts are backed up if you save all contacts in your Gmail account (instead of SIM card).
