How to Change the Vibrate Shortcut
By default, pressing the Power and Volume Up buttons simultaneously will put the Teracube into “Vibrate” mode for all notifications. If these buttons are pressed accidentally, the phone may stop ringing unexpectedly. Some people might like this shortcut - some may not.
To change this behavior, go to Settings > Sound and select “Shortcut to prevent ringing”. Tap “Press Power & Volume Up together”, then select a new behavior - either “Mute” or “Do nothing”.
Thank you!! This is probably how my phone has gotten to be muted before accidentally.*
(and then I found that volume up didn’t automatically adjust ringer)
*or not, but good to know
I have been using this shortcut more often since last few days - kind of like it as a quick way to silence/vibrate the phone.
