If your child’s wireless plan has ended, you can reactivate it as follows:
- Visit myteracube.com/wireless and log in using your email address
- Click “Add a plan”
- Select your SIM from the “Your SIMs” section.
- Select a plan.
- If you get the below screen, use the “New phone number” option. This will allocate your old number back to you (if still available)
If you have any questions, please email us at support@myteracube.com or schedule a call at myteracube.com/schedule.
