Hello all, continuing with the volume discussion, my phone is too loud for me even on the lowest volume setting. Does anyone have any good suggestions for how to adjust this, and/or know if it is possible to adjust? I tried a couple of apps but they did not help. (for example, the app “precise volume” lets you have additional volume levels but it does not change the range). Thanks!
Could you clarify which volume is too high - Media, Call, Ring or Alarm? And could you share a screenshot of your sound settings at Settings > Sound.
ps: moved this to its own topic.
Hello, it is mostly the media volumes, and sometimes the call volumes. I did a little testing and it does not seem to be all apps, but just some of them. For example, my media player (AIMP) is too loud. It is too loud if I have head phones on, and through the speakers/speaker phone. Youtube is not as loud but boderline on the lowest setting (with my headphones on).
Also in general everything is too loud for me through the speaker phone (both calls and media).
thanks!
Hi, I am having the same problem. I use the earphones on my ears instead of in my ears, even at level 1. It concerns media and especially call. I tried also several apps without success.
Thanks for helping!
We can address it in our Android 10 build. If you will like, you can give a spin to our Alpha build and help us finetune the volume settings. I and a few others are using it as our daily driver.
