Update: The link in step 2 below now points to the latest Alpha9 build. Note: Alpha builds will require data reset while upgrading - we are looking into this issue. Everything else works.
We are very excited to announce that we have an Alpha version of Android 10 available for testing on Teracube One. The Dev team has been hard at work implementing Android 10 features and fixing bugs.
The build itself has gone through some internal testing and will/does have issues - that’s the whole point of more testing
** Warning **
Not for the faint hearted. This is Alpha stage software. If something goes wrong, you might lose your data and might have to re-flash Android 9 using SP Flash software.
What works: Check changelog here.
Almost everything - VoLTE, VoWiFi, Fingerprint, LTE, Google Play store, WiFi, Bluetooth, NFC, Proximity sensor and more.
What does not work yet: LED notification light, Google Pay.
Steps
Backup your data. This install will erase your userdata. So you will have to do a fresh restore from Google or elsewhere.
Download the A10-Alpha zip file - version 9 and unzip it on your Windows 10 PC.
Unlock bootloader and stay in Fastboot mode.
– If your bootloader was already unlocked, then simply go to fastboot mode using the steps in bootloader unlocking. -
Connect the phone to the computer.
Go to the downloaded folder and double-click the “flash-all.bat” file. It will flash all partitions and reboot the phone automatically.
The script will take few minutes to flash all partitions.
- After reboot, setup the phone per your user preference.
That’s it - now you are part of our Android 10 testing group (Welcome!). Report any bugs/issues on this post (Known issues listed above).
