Minimum adaptive brightness 31%
On the Teracube 2e, no matter how dark the room I’m in, the minimum brightness for “Adaptive Brightness” mode is 31%. What’s weird is that if I turn off adaptive brightness, I can drop it all the way to 0% and it’s much better (perfect for a completely dark room).
Is there any way to change this? At first I thought this was a limitation of an IPS screen, but it’s frustrating that the screen is fine and the software just makes this phone way too bright at night. Turning adaptive brightness of is a workaround, but it’s really annoying to have the automatic mode not work.
Sorry about that - it is a bug as of now. The adaptive brightness slider does not allow to go to the lowest setting - it kicks back up to a higher setting. We will get that fixed in the next SW release.
I think the slider problem is more complex (or there is another one…). If set to “adaptive”, it doesn’t seem to remember its position! I prefer relatively bright settings, but I often find it lower than I had set it. Especially after the screen was off, I often find a very dark position. But not always - I was not yet able to identify the “rules” it seems to follow.
However, it looks like the slider (sometimes?) follows the ambient light level, but in my understanding, it shouldn’t - it should merely determine the “range” in which the adaption can take place.
Hi @mare - could you confirm if you have the original firmware (SW6) or the latest SW16?
I’m not sure. My 2e is as it was delivered, I didn’t notice any automatic update since then. If I open Settings > System > Updater, it says
Android 10
Teracube_2e_EEA_01
(last check: today)
UPDATED
Your device is up to date
I didn’t do a manual update, as your linked posting said it’s not for EU (I’m in Germany).
Yeah we just released Beta version of EEA-2 (equivalent to SW16). You could either install it now or wait for it to be certified.
Thanks, Sharad.
As I can live with the problem for now (I just wanted to let you know), I’ll be waiting with the update until it installs automatically.
