Screen unlock by fingerprint unavailable
I just received my phone and was trying to set up the fingerprint option to unlock the phone. I was able to add my fingerprints, but it does not give me the option to use it for screen unlock in security settings. Any advice?
Hi there - sorry for the late reply. Please do the following:
  1. Check if you have the latest software version by going to Settings > System > About > Wireless update.
  2. Perform a cache reset.
  3. If that does not fix the issue, then perform a backup and factory reset.
Thank you Sharad!
With Kindness,
Casey R Brown
I ran into the same issue here regarding fingerprints. All fingerprint related stuff was gone, OS and applications. Support suggested a factory reset, but luckily I found this entry.
Cache reset did it. Everything is working fine again.
Thanks to Sharad for saving my day.
Best regards from Austria,
Robert
