Sometimes my phone freezes
My phone freezes sometimes and I have to end up restarting the phone. Has this issue happened to anyone yet?
No, I’ve never seen that behavior yet.
Are you on sw06 or sw07?
I’m on Sw07 currently.
Is it reproducible with a certain sequence of actions, location, wifi or any particular app?
If the freezing was not happening earlier, then a cache cleanup or factory reset should fix it.
I think Spotify is the culprit.
Are you sure? It’ll be great if you can play around a bit and see if that’s reproducible in a particular way. Some of us can try it out then.
I have DuraSpeed turned on for my Spotify. Idk if that’s the issue.
