Yes - this is something that we have heard loud and clear from the community. The LED can be enabled/disabled in the software and we should have a setting for that in the next update.
Good to hear, iād love to be able to set it just for new notifications as well.
Just adding my voice to the chorus: I find notifications to be a completely passive activity - they exist as a list that I look at when I want to look at it, and to alert me (normally via my watch) when something new comes in, but other than that⦠no. I donāt want a light flashing 24/7 telling me that my phone has notifications. It always does.
Anyway, glad the request is heard, and looking forward to the update. Itās a very minor thing compared to the other more serious issues Iāve got with the 2e, but will still be a welcome improvement
Also looking forward to it! Thanks for looking into this
@Sharad Is there any update on this⦠My light is now flashing all the time screen, on or off. And none of the sliders in the settings make any changesā¦it just blinks all day every day⦠Iām temped to rip the phone apart and physically remove the ledā¦
Hi @Chaz_Alberti - I have raised the priority for this setting addition (option to disable notification led). Will follow up soon.
Might be worth mentioning that the option is already there (search ālightā in the settings - Notifications ā Blink light), but it just doesnāt work to disable it.
Honestly, part of it is just not knowing what the light is trying to say. If I had to suggest a more user-friendly thing to do, an option to wake/light the lock screen when a notification makes a sound would be nice. A step further would be to isolate the notification that caused a sound alert, and display only that notification (but we canāt have everything, lol). When the phone makes a noise, it gets my attention and I look at it - would be nice if itād display what itās making noise about
At the moment, just a light that says āsomething is in the notification queueā is useless, as thereās always something (often many things) there. haha
is that changing light color on the terracube 2e?
I do not believe so, no.
Just to share a little bit on what I have realized. Seems anything in teracube 2e notification tray triggers the LED light. I just realized my Google weather forecast also can trigger it. As temporary solution for the bright LED light, I just put it upside down since the case corner can prevent the screen from touching the surface where I put the phone on.
Do I understand correctly that up to now there is no possibility to disable the LED? It is disturbing in the night. Always telling āLook at me Look at meā
Not yet. We have a code patch to disable the LED completely - will make its way to the next build.
I canāt believe this is still an issue that hasnāt been solved. I have to put the phone under a blanket to be able to sleep. Total fail! Please find a way for us to eliminate that in our 2eās. Please.
ā¦any update on this? The piece of plastic i glued to my phone to block the light finally fell off⦠Can we get an update on when this is getting patched outā¦Before i rip open the phone to remove this cursed light. I tried disabling it in the setting again but it still doesnāt seem to work⦠so the light still flashes constantly screen on or off⦠notification or no notificationā¦
Hi @Chaz_Alberti - The fix is part of our Android 11 build which is behind its schedule now. We will post on forums (and send email) once it is ready.
Just upgraded to android 11⦠and it still flashes constantly
It appears to still constantly blink while battery saver is on and then the light is on constantly while plugged in
LED light notifications have been improved quite a lot from Android 10. We will bring in additional control later.
I have been updated to android 11 since they were available and I feel like only recently (in the last month or so) have I noticed that the light is always blinking again. It was corrected at some point but seems to have reverted. Maybe in 11.0.2 it came back and Iām just realizing?
@Sharad any thoughts? Is the 11.0.3/4 good to download now and itās fixed in that update? not clear from the main thread
Just polishing up a few things on 11.0.4. Should have it out soon. And yes - it should have the notification-led fix as well.
