I’ve had my teracube 2e for just over a month now. I’ve never got mobile data to work on it yet (which isn’t a huge issue for me but it would be nice to be able to get MMS messages). Not really sure where to start looking for the problem or fix. I’m on /e/OS 0.18-20210828132307 … I am considering trying regular android to see if it works there or not (is it worth trying this?). My carrier is Tello on the t-mobile network. Everything else that I’ve tried to use is working well.
Things I’ve tried so far:
enable roaming
change preferred network type to 3g
change preferred network type to 2g
turn off mobile data / turn it back on
turn off “automatically select network” – this brings up a “choose network” page which is blank.
And yes, I am on a 2gb data plan (plenty for my use case)
Any thoughts what to look at next? Is it more likely to be a hardware issue, or an os issue, or some kind of compatibility problem with my carrier?
