Check out the newer 11.0.4 update.
Archive
Note : This update is for the 1st batch of T2e (SN:2020 / codename:zirconia)
** Warning **
- Check Known issues below before proceeding.
Here is our 4th stable (11.0.3+2ef5777.user) and (Google) certified Android 11 for Teracube 2e (1st batch; SN 2020).
We’ve been listening to your concerns, regarding performance degradation, input latency, downstream 4.9 kernel, oddly high first-boot times and issues with some carriers. This build is based on emerald’s (2nd batch; SN 2021) SW5 build, to bring you it’s enhancements, and upstream security and code while staying close and true to your previous UX.
Full rebase onto 4.19, MediaTek performance and upstream Google + Linux security improvements, and more; changes since emerald’s A11 SW5 build:
- Common kernel-4.19 support
- Added some critical upstream security patches
- Full itrusty/km3 support for zirconia
- Fixed provisioning settings on failed Settings DB upgrade (Unified → Alps only)
- Fixed issues with power down (partial ATF upgrade)
- Added double tap to sleep on home screen
- Added clear all to home screen
- Added new ringtones
- Switch to in-house Camera app for faster and more reliable image capture
- Changed system accents to blue
- Added GMS common default wallpaper (old wallpapers retained)
- Added ringtones and sounds from Unified (old sounds retained)
- Improved IMS support for many Europe carriers
- Added new bootloader graphics
Known Issues:
Few users have reported losing their previous SMS. We are looking into this issue urgently.
Users have reported not being able to unlock their device after the update, when a password is set (PIN and Pattern are fine). Please either temporarily remove your password, or temporarily switch to a PIN/Pattern before the update.
We have found the root cause, and are actively working to fix this issue.Please proceed only if you are ok with the 2 known issues above.
This update is broken. We have removed the link and are working on a fix.
Upgrade from Android 10 (SW6, SW16, EEA1) or Android 11 (11.0.X):
- Download the [upgrade zip] file directly on the phone (or transfer the zip to the phone).
- It will take a while. The phone will power off and restart by itself. Don’t press power button.
Do note, some users have reported that they lose their launcher - icon and widget arrangement. We’d suggest you take a screenshot of your homescreen before performing the update!
If you experience any errors/issues, you can flash SW6 (original Android 10 firmware) using these instructions.
