Note 1 : There is the 11.0.3 update available now.
Note 2 : This update is for the 1st batch of T2e (SN:2020 / codename:zirconia)
** Warning **
- Check Known issues below before proceeding.
Check out the newer 11.0.3 update.
Archive
Here is our 3rd stable and (Google) certified Android 11 for Teracube 2e (1st batch; SN 2020). Major performance improvements, and some quality-of-life and bug fixes included; full list below:
Fixes from 11.0.1
- Added Recorder
- Fix all outstanding performance issues
- Update GMS packages
- Fix reported issue with alarms - switch to Google Clock
- Add Google Calculator
- Other misc changes
What works
- Google Certified - so Google Pay, Netflix, Disney+ all work.
- Will work for all regions (US, Canada, UK, EU, Rest of the world)
- Bluetooth music and calling, NFC, WiFi, Cellular, VoLTE - all work
- Notification LED behavior fixed.
- Bluetooth range and music skipping issues should be fixed.
- FM Radio and Hotspot are fixed.
Known issues - What does not work yet
- Not a bug but more of an Android 11 feature. SIM cards can’t be disabled individually for Dual SIM setups.
Steps
Upgrade from 11.0.1/11.0.0:
- Open the updater app and tap the “Refresh”/Check for updates button [
] in the top-right corner. - You should see a new update to “11.0.1 or 11.0.2 depending on which build you were on”.
- Download and Install the update.
- If you go to 11.0.1 first, then repeat steps 1-3 for updating to 11.0.2.
Upgrade from Android 10:
- It will take a while. The phone will power off and restart by itself. Don’t press power button.
If you experience any errors/issues, you can flash SW6 (original Android 10 firmware) using these instructions.
