How can I find my child's phone? [Answered]
There are two options to find / locate your child’s phone:
  1. You can use the Google Find My Phone website from your PC. You will need to log in with your child’s Google account.
OR
  1. If you have Google Family Link enabled, then you can ring your child’s phone from the Google Family Link app or by visiting https://familylink.google.com/ on a desktop. Tap on the phone under your child’s profile, and you will see the option to make it ring.
