Incoming phone call audio "mostly" gone!
Just this morning I tried to make a call but since I heard nothing I assumed that the call did not go through. Hung up. Then the callee called me back and I heard no voice. Texting with him I Iearned that he heard me! Various tests indicate that:
  1. if I put on the speaker the audio comes through
  2. if I plug in a headphone (just TRS) the audio comes through the earbud
  3. missing audio includes the “calling” tone
    Anything I should try? I believe that I did a restart with no change.
You can try the following in sequence to see if anything fixes this issue:
  1. Goto Settings > Apps & notifications > Search for “Phone” > Clear Storage
  2. Soft reset.
  3. Backup and factory reset.
Hello,
I have the same problem as described by @1000dB.
I can’t find any solution on this forum neither on the /e/os/ discourse
(I can see that several thread asking help about the same problem).
I have a teracube 2e SN 2021 with /e/os 2.5 s emerald.
I already try all these steps:
But the problem persist.
I’d like to able to make phone call with my phone, any help is very much appreciate.
Thank you very much
So to be clear, are there situations where the earpiece volume is appropriate, or is it always low?
