This might come in handy if you are experiencing any app, call or other general issues with your phone. Try it before doing a full factory reset. Thanks to @Frontpage32 tip here.
- Goto Settings > System > Advanced > Reset options. Alternatively goto Settings and type “reset app” in the search box.
- Select the option “Reset app preferences” and hit “Reset apps”.
