So I attempted to install iodeos first. I follow the instructions to unlock bootloader, then disabled android verIfied boot.
When I reach the Step 2 of flash twp recovery
Reboot to bootloader using adb reboot bootloader
So I inputted the command “adb reboot bootloader”
It didn’t work, it said something along the lines of waiting for device. I researched on it and was able to reboot to bootloader using this command instead fastboot reboot bootloader.
I was able to flash twrp recovery however when I use the command fastboot reboot I wasn’t able to boot in TWRP but to OS setup (when you turn on the phone for first time to set up)
I gave up and lock the bootloader which gave a red state error which i had to to unlock. Then I went to install /e/ os using their installer. Successfully it did which I felt a relief. However everytime when I reboot the phone, the orange state appears. The phone is usable, the os and apps works fine just the reboot thing.
No sure, if I screwed up the phone security or do I need to reinstall everything. Any advice or guidance would be greatly appreciated.
