Where is the SD located on the phone. DO you have a picture of all the phones external interfaces (buttons, etc) Thanks
It’s the second slot where you put your nano SIM card. You need a micro SD card.
In the 2s, it’s the internal slot adjacent to the top of the battery. There is a tiny icon to identify it. The battery has to be removed to insert the SD.
