Thanks Sharad & ECS for your replies.
Some caveats and updates to my post:
āBroke video calling & FM radioā: Sorry, I should have been more explicit in mentioning it most likely broke my PROVIDERāS (T-Mobile) ābuilt-inā video phone calling features, or more likely its access to the stock ROMās built-in video calling⦠Whenever I used stock ROM to video call my girlfriendās phone (sheās on Mint which is technically T-Mobile), I had no problems (same with stock included FM radio app). However, whenever I installed Lineage and /e/ and tried same (using āvideo callā feature in contacts, etc), I could see her but she would just see a blank screen. Just conjecture on my part, but Iām assuming this might be due to any possible proprietary āclosed sourceā nature of those services? Or perhaps T-Mobile just didnāt like the interface or lack of T-Mobile friendly Google Services or something? If thereās a simple fix to this Iām not aware of, please post it! Iām handy with hacking and some coding, but these questions are a little above my pay grade. Hoowever, if this is just a T-Mobile thing, I get that thereās probably not much anybody can do about it. Everything else I really liked about Lineage and /e/ for this phone, so if I could get both those features on those ROMs, that would be wonderful.
Also, both alternative OSs just didnāt even have an FM radio option pre-installed (I tried various 3rd party FM radio apps but no dice).
āFlashing zipsā: Exploding forehead slapper here, but can you believe that in all the years Iāve been flashing ROMs and rooting my phone I never actually knew that you could use ADB to flash zips just like with TWRP because I never saw it EXPLICITLY mentioned on any forums or instructables as an alternative? I kind of suspected it, but since all instructions Iāve come across mention TWRP explicitly with no alternatives, I was too afraid to brick my phone to experiment around with it on such high-level system hacks without knowing EXACTLY what I was doing. Iām also the kind of guy who can prove you absolutely wrong when youāre giving me directions and say āyou canāt miss itā -
- I can and do.
Examples
*This article mentions only various paid apps but doesnāt mention ADB that I could see (theyāre prob really just helpful looking ads):
*This instruction (as a generic example among many Iāve found) on how to install MicroG (scroll to end of article) only mentions TWRP:
says things like
"14. install SuperSu via TWRP
- or use
adb sideload from the Advanced menu in TWRP
- install Xposed via TWRP (see 14.)"
and
āOnce Google is cleaned up and the FakeGapps module is ready, reboot into recovery (see 12. and 13.) and install the NanoDroid zip via TWRP.ā
After your post I did a search with the right terms this time and found a Quora article which says:
āDownload adb driver and install
Put the Zip File in one folderā¦
Open Command Promptā¦
Type adb devices
Your Device will listed
Then type adb sideload filename.zip
Your zip file will be installedā¦ā
Easy peasy. So apparently I had to know the right answer before I searched for the answer I didnāt know. Super frustrating. To be fair I have done a LOT of searching and bookmarking and came up with bupkus on the subject - maybe just bad luck on my part. Thatās really all thatās been holding me back - if I never needed TWRP to begin with, Iām okay with it since installing it has always been a bit of a pain in the butt anyway. Either way, your reply sent me down the right path, so thank you!
Iām going to try and install Xposed and MicroG, and if successful, Iāll post a full instructable on all the steps I followed to leave a breadcrumb trail for any other Teracubers interested in same. Iāll also take your advice and post up the video call/FM radio issue on the /e/ forums to put eyeballs on that as well.
Thanks!
