[Important Read] Difference between the 2nd batch VS 1st batch of Teracube 2e
Important Note: Do not install factory image meant for a different T2e batch or lineage or /e/ OS before reading this
There are two batches of Teracube 2e (T2e) so far
  1. 1st batch - Serial number starting with 2020 (internal codename: zirconia)
  2. 2nd batch - Serial number starting with 2021 (internal codename: emerald)
How to identify the batch
Check Serial number (SN). (Under the battery or dial *#06#)
  • The 1st batch starts with “2020” in their SN. Sample - 2020xxxxxxxxxxx
  • The 2nd batch starts with “2021” in their SN. Sample - 2021xxxxxxxxxxx.
What’s different in the 2 batches
While all the hardware specs are still the same, we had to change the Trustzone and TEE (related to fingerprint, IMEI, etc). This means software builds are different. Both versions run Android 11 now. Check out A11 for the 1st batch here.
Update: There is a Lineage build for the 2nd T2e batch (SN: 2021) now.
/e/ OS Update: /e/ OS can now be installed on 2nd batch units as well. Read more here.
[Certified] Android 11 for Teracube 2e 1st batch (SN: 2020)
[Advanced Users][11.0] LineageOS 18.1 [UNOFFICIAL][2e]
Updates on Android 11 for Teracube 2e (1st batch - 2021)
[Advanced] Installing factory Android image w/ SP Flash
[Advanced users] How to install Lineage (or any) GSI on T2e
[Advanced Users Only][Teracube 2e 2nd Batch (SN: 2021)] LineageOS 18.1 Beta [emerald]
[Final Beta] Android 12.1 for Teracube 2e (both batches)
/e/ OS installation for Teracube 2e (both batches)
[Certified] Android 11.0.2 for Teracube 2e 1st batch (SN: 2020 / zirconia)
[Certified] Android 11.0.1 for Teracube 2e 1st batch (SN: 2020)
Teracube 2e Review
How to install LineageOS 17.1 GSI on the teracube 2e
[Certified] Android 11.0.4 for Teracube 2e 1st batch (SN: 2020)
[Advanced Users Only][Android 12L][Teracube 2e 1st Batch (SN: 2020)] CipherOS 3.8 [zirconia]
[Certified] Android 13.1.1 for Teracube 2e Emerald (SN:2021)
[Certified] Android 13.1.1 for Teracube 2e Zirconia (SN:2020)
Android 15.0.1 for Teracube 2e 1st Batch Zirconia (SN: 2020)
[Guide][Advanced users only] Root for Teracube 2e (2nd batch, SN:2021) (emerald)
[Advanced users only] TWRP recovery + root for Teracube 2e (1st batch, SN:2020)
Suddenly lost calling capabilities
[Advanced Users][10.0][BETA] LineageOS 17.1 [UNOFFICIAL][2e]
[Alpha Build] Android 11 for Teracube 2e (2021 - 1st batch)
[Beta] Android 11-April 2022 (A11-SW7) update for T2e 2nd batch (SN:2021)
Front facing camera not opening since o/s update?
[Broken] [Certified | Pre-rollout] Android 11.0.3 for Teracube 2e 1st batch (SN: 2020)
Frame rate screen
[Alpha] Android 12 for Teracube 2e
Teracube 2e (2022 Batch) Lineage Open Beta Invite
[Advanced Users Only][Teracube 2e 2nd Batch (SN: 2021)] LineageOS 21.0 [emerald]
Android 16.0.1 for Teracube 2e 1st Batch Zirconia (SN: 2020)
Android 16.2.0 for Teracube 2e 2nd Batch Emerald (SN: 2021)
[Certified] Android 14.1.0 for Teracube 2e 2nd Batch Emerald (SN: 2021)
[Certified] Android 14.1.0 for Teracube 2e 1st Batch Zirconia (SN: 2020)
Android 15.0.1 for Teracube 2e 2nd Batch Emerald (SN: 2021)
Will there be an update here when eOS is working for the 2nd batch? Or should I be watching the /e/ forums for that?
This is a bit confusing.
Is the current /e/ build incompatible with the 2nd batch, or does the installation procedure just need to be different?
Thanks
The current /e/ build and the process - both are incompatible. The /e/ team is working on it and should post their forums. We will post an update here as well.
Is there any update on this? Do you guys need any beta testers
Hi,
I am a little confused. Is there a version of aosp that can currently be installed on the 2022 revision? The first numbered point of the post sounds like maybe there is, but I’m not sure.
I really don’t want Google all over this phone if I can help it :grinning:
TIA,
Mike
Apologies for the confusion. Update: There is a Lineage build for the 2nd batch (SN: 2021) now.
As of now, there is no AOSP/Lineage/eOS build compatible with the 2nd batch (SN: 2021) . The OSS Team is working on a Lineage/AOSP version with eOS to follow.
Super! Looking forward for Lineage:)
Thanks. Hopefully one of the versions arrives soon! I’ll leave it in the box til then.
Leaving mine in the box too for the same reason.
Unfortunate, since AT&T will abandon my old phone at the end of Feb.
I decided to try mine out when it arrived today. I moved the SIM to the 2e, called Red Pocket (AT&T version), since it didn’t work out of the gate, and they did some tweaks at their end and it started working, albeit on the awful Google version of Android 11. It would only work for a few minutes however before it stopped receiving and making calls. Data and texting worked, but no voice calls. 5 support calls and several hours of SIM removal and re-insertion and restarting have not improved the situation, so I am giving up and sending it back.
I may have kept it despite the Red Pocket issues if it could have run Lineage or /e/, but I didn’t find out that it couldn’t until after I paid a $100 premium over the original 2e that did run them, which kind of took the bloom off the rose to start with.
Hopefully some of the Linux phones will mature soon :slight_smile:
It’s too bad the 2e didn’t work with your provider, but as an owner of a 2e and a pinephone, I will say, the 2e is much closer to primetime ready than the Linux phones. While LineageOS doesn’t work yet on the 2022 batches, I trust that they are working on it. Currently (at least for most of us) we have a brand-new, functioning phone with decent specs and an unlockable bootloader for around 300 USD. Once I enabled certain apps under Duraspeed, I was able to view all my notifications in real-time with no issues. I can’t say the same for my Pinephone yet, and I’ve had it for 2 years. I wish both projects the best, but I believe Teracube’s product is much closer to production-ready than the Linux phones at this time, but still impatiently waiting the release of LineageOS for this as well
If y’all were gonna make changes like that, then you could have at least swapped in a new usb chipset that allows usb-c to usb-c cables and power adapters.
I mean… wow, like, all around. Never heard of something like this happening. The “same” phone will now need two different development paths? That’s bad. Bad for the promise of 4 years of support, bad for official rom development, and really bad for custom rom dev.
Gotta say I’m on the same page as Icantremember. Requiring a separate build but not calling the device something different is as confusing as Motorola’s making scheme. I also feel a bit cheated on that I thought I was paying $300 for a device that already has an established aftermarket ROM community in /e/, Lineage and Iode just to find out that it’s a different device but with no improvements. On top of all that not having any updates since October! On an apparently new for 2022 device (how does that even work). Really feels bad.
Hey - sorry to keep you all waiting. I am ready with a build for LineageOS, I just need to set up OTA and flashing infrastructure. Once all of that’s sorted out (I’m also busy with my exams) so latest by next Monday (trying to pull the date back to tomorrow or so) you’ll have a Lineage build working fine on Android 11. Android 12 is too, in the works, so I’d request you to please wait!
I’m excited for the Lineage release :slight_smile:
(super spoiler: /e/ is also in the works)
Awesome! Thanks for all you do
Will there be an OTA update from Lineage 18 to 19, or would that be a reflash?
Update: Looking for folks to join open Beta of Lineage. Read more here.
I have not worked on 19 yet. It’s a work in progress - I’ll share details on that by the next month, hopefully.
Work was prioritized to get Lineage-18.1 out for the new batch so that the community still remains vibrant as ever.
And yes, I think we can do that - moving to 19 via OTA. I’ll get it to work first xD
Awesome, just checking. Thanks again!
